[GRASS-dev] [GRASS GIS] #2036: Failed watershed analysis on Grass
trac at osgeo.org
Thu Jul 18 23:49:58 PDT 2013
Reporter: mehmeto | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 6.4.4
Component: Raster | Version: 6.4.2
Resolution: fixed | Keywords: LFS, r.watershed
Platform: MSWindows 7 | Cpu: x86-64
Comment(by mmetz):
Replying to [comment:6 mehmeto]:
> Tried to do the same analysis with Spearfish data that also is in the
installation package and it worked. It should be a memory problem indeed.
(although Spearfish map looks larger) Thanks for your replies.
You need to run r.watershed in disk swap mode with the -m flag. Also be
aware that even for smaller regions, the size of the temporary files can
be quite large, and LFS for Windows is only available in GRASS 7.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2036#comment:11>
