[GRASS-dev] [GRASS GIS] #2036: Failed watershed analysis on Grass
trac at osgeo.org
Fri Jul 19 10:46:09 PDT 2013
Reporter: mehmeto | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 6.4.4
Component: Raster | Version: 6.4.2
Resolution: fixed | Keywords: LFS, r.watershed
Platform: MSWindows 7 | Cpu: x86-64
Comment(by glynn):
Replying to [comment:10 hamish]:
> ok, I mostly meant if it was desired to make the binaries a bit smaller
or not since it looks like mswindows/osgeo4w/package.sh is not stripping
them.
Distributed binaries ought to be stripped (or compiled without -g in the
first place), regardless of platform. If you don't specify CFLAGS when
running configure, it defaults to "-g -O2".
"objdump -h <filename>" will confirm whether the binaries contain debug
information (if there are sections whose names start with ".debug_", the
file isn't stripped).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2036#comment:12>
