[GRASS-dev] [GRASS GIS] #2036: Failed watershed analysis on Grass
trac at osgeo.org
Fri Jul 19 11:02:12 PDT 2013
Reporter: mehmeto | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 6.4.4
Component: Raster | Version: 6.4.2
Resolution: fixed | Keywords: LFS, r.watershed
Platform: MSWindows 7 | Cpu: x86-64
Comment(by mehmeto):
Replying to [comment:7 hamish]:
> this isn't really that large of a region, you usually hit 2 GB files at
~ 45000x45000 rows x cols. this is much smaller,
> > If you calculate 4 * 60175190 bytes = 240700760 which is > 2^31.
> missed a 0, actually it's 9 times smaller than 2^31. It only wants to
allocate 241mb RAM, so probably not a large-file problem. How much do
memory does your computer have?
It has 8GB.
Also thank you for updating the tutorial.
Now I can do watershed analysis at least on a demo map but my real data
will be larger. I will need to work on an area of about 5,000 square km.
and the map scale will be about 1:25,000 or even lower. I will also need
to transform contours to DEM before start using r.watershed. Since I will
work on a PC, memory problems seem inevitable.
I know one suggested method to overcome memory limitations is dividing a
large map to smaller pieces but in a wathershed analysis that will mean
false or missing results. Or, maybe I will need to divide the map into
overlapping sections to make sure no basins are missed and then manually
stitch the sections, which sounds to me a very laborous procedure now. Do
you have any ideas how to do that, or any forums where I can ask?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2036#comment:13>
