[GRASS-dev] [GRASS GIS] #2036: Failed watershed analysis on Grass
trac at osgeo.org
Fri Jul 19 11:07:24 PDT 2013
Reporter: mehmeto | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 6.4.4
Component: Raster | Version: 6.4.2
Resolution: fixed | Keywords: LFS, r.watershed
Platform: MSWindows 7 | Cpu: x86-64
Comment(by mehmeto):
Replying to [comment:11 mmetz]:
> You need to run r.watershed in disk swap mode with the -m flag. Also be
aware that even for smaller regions, the size of the temporary files can
be quite large, and LFS for Windows is only available in GRASS 7.
Thank you. So, I undertand that current stable version of Grass for
Windows is not a convenient program to do such an analysis on a large map.
I should either wait for Grass 7 release, or find a Linux / Mac machine or
use another GIS?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2036#comment:14>
