[GRASS-dev] [GRASS GIS] #2036: Failed watershed analysis on Grass
GRASS GIS trac at osgeo.org
Fri Jul 19 13:01:25 PDT 2013
  Reporter:  mehmeto      |       Owner:  grass-dev@…
      Type:  defect       |      Status:  closed
  Priority:  normal       |   Milestone:  6.4.4
 Component:  Raster       |     Version:  6.4.2
Resolution:  fixed        |    Keywords:  LFS, r.watershed
  Platform:  MSWindows 7  |         Cpu:  x86-64
Comment(by mmetz):
 Replying to [comment:7 hamish]:
 > It only wants to allocate 241mb RAM, so probably not a large-file
 problem. How much do memory does your computer have?
 If your machine has, say 8 GB, and 8 GB are already allocated, trying to
 allocate further 241 MB will fail with an out of memory error.
 > for what it's worth, some LFS notes:
 LFS for GRASS on Windows is only available in trunk, and there it is
 enabled by default. By default, Windows, also a 64 bit Windows, does not
 have LFS when using the standard API, you need to use the LFS API
 explicitly.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2036#comment:15>
