[GRASS-dev] [GRASS GIS] #2036: Failed watershed analysis on Grass
trac at osgeo.org
Fri Jul 19 13:06:24 PDT 2013
Reporter: mehmeto | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 6.4.4
Component: Raster | Version: 6.4.2
Resolution: fixed | Keywords: LFS, r.watershed
Platform: MSWindows 7 | Cpu: x86-64
Comment(by mmetz):
Replying to [comment:14 mehmeto]:
> Replying to [comment:11 mmetz]:
> > You need to run r.watershed in disk swap mode with the -m flag. Also
be aware that even for smaller regions, the size of the temporary files
can be quite large, and LFS for Windows is only available in GRASS 7.
> Thank you. So, I undertand that current stable version of Grass for
Windows is not a convenient program to do such an analysis on a large map.
I should either wait for Grass 7 release, or find a Linux / Mac machine or
use another GIS?
For Windows, you can use the GRASS 7 installer available at
http://wingrass.fsv.cvut.cz/grass70/
Most GRASS 7 modules are at least as robust as in GRASS 6, and r.watershed
in GRASS 7 is suitable for production work. In GRASS 6.4.2, r.watershed is
IMHO not suitable for production work.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2036#comment:16>
