[GRASS-dev] g.extension.py at (win)grass7-wxgui-startup needed?
Vaclav Petras
wenzeslaus at gmail.com
Mon Jul 22 04:16:37 PDT 2013
On 22 July 2013 12:18, Helmut Kudrnovsky <hellik at web.de> wrote:
> hi,
> system here:
> System Info
> GRASS version: 7.0.svn
> GRASS SVN Revision: 57202
> Build Date: 2013-07-18
> GIS Library Revision: 56211 (2013-05-12)
> GDAL/OGR: 1.9.2
> PROJ.4: 4.8.0
> GEOS: 3.3.6dev
> SQLite: 3.7.10
> Python: 2.7.4
> wxPython: 2.8.12.1
> Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
> it seems that g.extension.py is called when grass7-wxgui is started.
Since r57144 menu can contain an entry which will show the list of
installed addons. In the current version, the addons entry is included
in Search module (in module tree) if some addons are installed.
[1] http://trac.osgeo.org/grass/changeset/57144
> is this needed?
g.extension is needed to list installed addons. If this is a problem,
installed addons can be retrieved from XML in addons directory
(calling `g.extension -a` is simpler, but parsing XML is also
possible).
Some days ago there was a bug in usage of find_program function which
in turn caused triggering of compilation by g.extension. This was
causing the compilation in current directory when starting wxGUI (at
least under linux). This is fixed now.
Vaclav
> best regards
> Helmut
> View this message in context: http://osgeo-org.1560.x6.nabble.com/g-extension-py-at-win-grass7-wxgui-startup-needed-tp5067923.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
