[GRASS-dev] g.extension.py at (win)grass7-wxgui-startup needed?
Helmut Kudrnovsky hellik at web.de
Mon Jul 22 04:33:25 PDT 2013
hi,
> Since r57144 menu can contain an entry which will show the list of
> installed addons. In the current version, the addons entry is included
> in Search module (in module tree) if some addons are installed.
> [1] http://trac.osgeo.org/grass/changeset/57144
> > is this needed?
> g.extension is needed to list installed addons. If this is a problem,
> installed addons can be retrieved from XML in addons directory
> (calling `g.extension -a` is simpler, but parsing XML is also
> possible).
> Some days ago there was a bug in usage of find_program function which
> in turn caused triggering of compilation by g.extension. This was
> causing the compilation in current directory when starting wxGUI (at
> least under linux). This is fixed now.
thanks for the clarification.
I've seen it, because every call of a python-script here at my WinVista- or
Win7-box pops up a window and asks how to open the script...
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/g-extension-py-at-win-grass7-wxgui-startup-needed-tp5067923p5067944.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
