[GRASS-dev] start grass with only initializing the environment
Markus Neteler neteler at osgeo.org
Tue Jul 23 01:35:34 PDT 2013
On Mon, Jul 15, 2013 at 5:44 PM, Rainer M Krug <Rainer at krugs.de> wrote:
> I would therefore suggest an additional startup argument for grass,
> which only sets the environmental variables, including library paths,
> so that GRASS commands can be executed afterwards, and if the
> LOCATION_NAME and MAPSET are not provided, they will be null and *have
> to be set manualy afterwards*.
> This could e.g. have the name "-noui" indicating that no ui will be
> started.
I wonder what the difference to starting GRASS 7 with  -text is...
Maybe that's already enough?
Markus
