[GRASS-dev] start grass with only initializing the environment
Hamish
hamish_b at yahoo.com
Tue Jul 23 03:00:33 PDT 2013
Rainer wrote:
> I would therefore suggest an additional startup argument for grass,
> which only sets the environmental variables, including library paths,
> so that GRASS commands can be executed afterwards,
just make your own batch file or function(){} for /etc/bash.bashrc?
> and if the LOCATION_NAME and MAPSET are not provided, they will be
> null and *have to be set manualy afterwards*.
that doesn't sound like a practice we should promote.
what part of the start up are you trying to avoid? ('grass64 -text'
works in 6 too, or 'g.gui text' to avoid the gui at startup)
see also the usage for GRASS_BATCH_JOB, which basically does that in
a non-interactive environment.
Hamish
