[GRASS-dev] [GRASS GIS] #1940: wingrass - nsis - script in release mode: !define SVN_REVISION "@GRASS_VERSION_SVN@" not set
trac at osgeo.org
Tue Jul 23 02:08:59 PDT 2013
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: Packaging | Version: 6.4.3 RCs
Keywords: nsis, wingrass | Platform: MSWindows 7
Cpu: x86-64 |
Comment(by hellik):
Replying to [comment:11 hamish]:
> from the subject of this bug it seems the issue has to do with building
an official versioned release, not with a random svn snapshot build?
> In that case the svn rev and thus svnversion are mostly irrelevant;
".svn/" metadata is not in the final tarball, and if a historian is
curious what svn rev the version refers to they can always look it up in
the tag's log.
see
http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/mswindows
/GRASS-Installer.nsi.tmpl#L251
!define /math VERSION ${SVN_REVISION} + ${BINARY_REVISION}
${VERSION} is used in the nsis-script/wingrass-installer to check if the
installer is newer/older than the already installed
Ticket URL: <http://trac.osgeo.org/grass/ticket/1940#comment:13>
