[GRASS-dev] [GRASS GIS] #1866: broken db driver communication in winGRASS 7
trac at osgeo.org
Wed Jul 24 07:06:07 PDT 2013
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Database | Version: unspecified
Keywords: sqlite, wingrass | Platform: MSWindows 2K
Cpu: Unspecified |
Changes (by mlennert):
* priority: blocker => normal
Comment:
Replying to [comment:42 neteler]::
> > > > Replying to [comment:34 hamish]:
> > > > > You may be seeing the effect of the db.* modules only working
for databases linked from maps in the current mapset
> Right. So we need a test for that rather than failing with a slightly
> obscured error message. Or expand it to say:
> "Table <%s> not found in current mapset"
The current test is this:
if (db_describe_table(driver, &table_name, &table) != DB_OK)
G_fatal_error(_("Unable to describe table <%s>"),
db_get_string(&table_name));
i.e. it justs checks whether it can describe the table and if not it
fails. No attempt to no why it cannot describe the table (table does not
exist in this mapset, bad spelling, etc). As the module does allow you to
define the driver and database (meaning that you can actually describe a
table in any database, not only tables in a database linked to a GRASS
mapset), the issue is larger than just mapsets. I would suggest something
like:
ERREUR :Unable to describe table <overpasses>. Check database connection
information.
and adding a few lines to the manual.
I'm attaching a relevant patch proposal.
In any case, I'm downgrading this bug's priority.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1866#comment:43>
