[GRASS-dev] [GRASS GIS] #1866: broken db driver communication in winGRASS 7
trac at osgeo.org
Wed Jul 24 07:08:34 PDT 2013
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Database | Version: unspecified
Keywords: sqlite, wingrass | Platform: MSWindows 2K
Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:42 neteler]:
> Replying to [comment:41 mlennert]:
> > Replying to [comment:39 mlennert]:
> > > Replying to [comment:38 neteler]:
> > > > Replying to [comment:34 hamish]:
> > > > > Replying to [comment:33 neteler]:
> > > > > > I have tried with r56943 on Windows8, still failing:
> > > > > > GRASS 7.0.svn> db.describe overpasses
> > > > > is the overpass vector map in the current mapset?
> No. I tried from the user1 mapset.
> > > > > You may be seeing the effect of the db.* modules only working
for databases linked from maps in the current mapset
This is not true. All db.* modules (should) have an option to define the
database and driver, as for example db.describe, which can describe any
table in any database, as long as the driver is supported.
> Right. So we need a test for that rather than failing with a slightly
> obscured error message. Or expand it to say:
> "Table <%s> not found in current mapset"
Better:
"Table <%s> not found in database <%s> using driver <%s>"
Done in r57260.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1866#comment:44>
