[GRASS-dev] g.extension error with r.in.redwg and r.fuzzy (GRASS 7)
Johannes Radinger johannesradinger at gmail.com
Thu Jul 25 02:22:09 PDT 2013
I tried to install two add-ons (r.in.redwg and r.fuzzy) for GRASS7 on
Ubuntu (latest revision 57266) but g.extension produces following errors:
g.extension -s extension=v.in.redwg svnurl=
http://svn.osgeo.org/grass/grass-addons/grass7
Fetching <v.in.redwg> from GRASS-Addons SVN (be patient)...
Compiling...
entity.c:39:17: fatal error: dwg.h: No such file or
directory
compilation terminated.
make: *** [OBJ.i686-pc-linux-gnu/entity.o] Error 1
ERROR: Compilation failed, sorry. Please check above error messages.
g.extension -s extension=r.fuzzy svnurl=
Fetching <r.fuzzy> from GRASS-Addons SVN (be patient)...
Compiling...
In file included from logic.c:3:0:
local_proto.h:21:0: warning: "MAX" redefined [enabled by
default]
/usr/include/i386-linux-gnu/sys/param.h:76:0: note: this is
the location of the previous definition
local_proto.h:22:0: warning: "MIN" redefined [enabled by
default]
/usr/include/i386-linux-gnu/sys/param.h:75:0: note: this is
In file included from main.c:18:0:
default]
default]
In file included from fuzzylogic.c:1:0:
local_proto.h:24:0: warning: "MAX" redefined [enabled by
default]
local_proto.h:25:0: warning: "MIN" redefined [enabled by
default]
In file included from helpers.c:1:0:
default]
default]
In file included from io.c:1:0:
default]
default]
In file included from main.c:17:0:
default]
default]
In file included from map_parser.c:1:0:
default]
default]
In file included from rule_parser.c:1:0:
default]
default]
In file included from system.c:1:0:
default]
default]
Installing...
make: *** No rule to make target `install'.  Stop.
WARNING: Installation failed, sorry. Please check above error messages.
(Thu Jul 25 11:18:53 2013) Command finished (10 sec)
Can anyone confirm that so that I can launch a bug note? Or is that easy to
solve?
Best regards,
Johannes
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130725/709c87ab/attachment-0001.html>
