[GRASS-dev] g.extension error with r.in.redwg and r.fuzzy (GRASS 7)
Markus Neteler
neteler at osgeo.org
Fri Jul 26 01:04:43 PDT 2013
On Thu, Jul 25, 2013 at 11:22 AM, Johannes Radinger
<johannesradinger at gmail.com> wrote:
> Hi,
> I tried to install two add-ons (r.in.redwg and r.fuzzy) for GRASS7 on Ubuntu
> (latest revision 57266) but g.extension produces following errors:
> g.extension -s extension=v.in.redwg
> svnurl=http://svn.osgeo.org/grass/grass-addons/grass7
> Fetching <v.in.redwg> from GRASS-Addons SVN (be patient)...
> Compiling...
> entity.c:39:17: fatal error: dwg.h: No such file or
> directory
> compilation terminated.
> make: *** [OBJ.i686-pc-linux-gnu/entity.o] Error 1
> ERROR: Compilation failed, sorry. Please check above error messages.
You need the LibreDWG to be installed, see
http://svn.osgeo.org/grass/grass-addons/grass7/vector/v.in.redwg/v.in.redwg.html
> g.extension -s extension=r.fuzzy
> Fetching <r.fuzzy> from GRASS-Addons SVN (be patient)...
> Compiling...
> In file included from logic.c:3:0:
> local_proto.h:21:0: warning: "MAX" redefined [enabled by
> default]
> Installing...
> make: *** No rule to make target `install'. Stop.
> WARNING: Installation failed, sorry. Please check above error messages.
> (Thu Jul 25 11:18:53 2013) Command finished (10 sec)
Fixed in r57277 (G7) and r57278 (G6),
Markus
