[GRASS-dev] [GRASS GIS] #1358: WinGRASS 6.4.1: SQLite driver errors: `Unable to open database'
GRASS GIS trac at osgeo.org
Thu Jul 25 03:52:20 PDT 2013
 Reporter:  rvanderweide             |       Owner:  grass-dev@…
     Type:  defect                   |      Status:  new
 Priority:  minor                    |   Milestone:  6.4.4
Component:  Database                 |     Version:  6.4.1 RCs
 Keywords:  wingrass, SQLite driver  |    Platform:  MSWindows 7
      Cpu:  x86-64                   |
Comment(by mlennert):
 Replying to [comment:10 mmetz]:
 > Replying to [comment:9 hamish]:
 > > unless someone has a bright idea for a minimally invasive fix, bumping
 it down the road a little ...
 > With GRASS default settings, i.e. the sqlite database in the default
 folder, this does not happen. Changing priority to minor, but the ticket
 could also be closed as invalid. Essentially, this is a sqlite bug with
 sqlite calling fsync() on the directory of the sqlite database even if the
 directory contains files not related to the sqlite database.
 With the latest wingrass7 (July 18), after installation and download of
 the NC data set, I get the following error:
 g.copy vect=roadsmajor at PERMANENT,roads2
 DBMI-SQLite driver error:
 Unable to open database:
 C:\grassdata\North_Carolina\user1\sqlite\sqlite.db
 unable to open database file
 no database is open
 Copy vector <roadsmajor at PERMANENT> to current mapset as <roads2>
 WARNING: Impossible d'ouvrir la base de données
 <C:\grassdata\North_Carolina\user1\sqlite\sqlite.db> avec le driver
 <sqlite>
 no database is open
 WARNING: Impossible de copier la table <roads2>
 WARNING: Unable to copy <roadsmajor at PERMANENT> to current mapset as
 <roads2>
 Is this related ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1358#comment:11>
