[GRASS-dev] Python handling in winGRASS7 [was: Re: GRASS GIS 7 tech-preview release preparations]
Moritz Lennert
mlennert at club.worldonline.be
Fri Jul 26 02:04:18 PDT 2013
On 26/07/13 00:04, Helmut Kudrnovsky wrote:
>> - One of the issues is whether and how to install Python. As Python is
>> needed both for the wxgui and for scripting, and scripting is something
>> for which you cannot assume an embedded Python interpreter, the
>> preferred solution would be to install Python system-wide using the
>> official Python installer (i.e. possibly having the GRASS installer test
>> for Python installation and if not present, propose to launch the
>> download and execution of the official Python installer).
> unfortunately and in contrast to Linux/(Mac?), there is 'normally' no
> 'unique' (system-wide) python 2.x/3.x installation in MS windows OS.
> windows user software may/may not bring their own embedded/system wide
> installed python versions.
> examples for software with embedded python without system wide registry
> entries:
> e.g.
> C:\Program Files (x86)\LibreOffice 4.0\program\python-core-3.3.0
> C:\Program Files (x86)\Inkscape\python
> examples for software with a system wide python installation _and_ with
> registry entries:
> e.g.
> C:\Python26\ArcGIS10.0
> C:\Python27\ArcGIS10.1
Yes, and AFAIU, especially via the explanations Glynn gave (notably in
[1]), the difference between the two options is whether you want to
a) use Python only from within the application, i.e. for internal
scripts (IIUC, in GRASS this would translate to scripted modules and the
wxGUI), which is the case for Inkscape and LibreOffice
or
b) use Python also for command line scripting in the general environment
and so install Python system wide (e.g. ArcGIS). In the idea that
scripts that call GRASS functions should run also when called from
outside a running GRASS "session", this would be the preferable way for us.
However, again IIUC, a) is much easier to implement via an embedded
Python interpreter, while b) causes the issues you mention concerning
library incompatibilities and the need to install missing necessary
Python packages.
So the big question is whether we think we can solve the issues related
to b) with a reasonable effort.
Would it be a possible option to implement only a) and document the fact
that the user has to take care of creating a working Python installation
herself if they want b) ?
Moritz
[1] https://trac.osgeo.org/grass/ticket/580#comment:53
