[GRASS-dev] Custom GRASS command line prompt
Nikos Alexandris nik at nikosalexandris.net
Sun Jul 28 13:39:41 PDT 2013
Nikos:
> > Now it appears like:  "G 7.0.svn (utm_37s/post):~ >".  My understanding is
> > that I probably need to edit the file:
> > grass7_trunk/dist.x86_64-unknown-linux-gnu/grass70.tmp
Hamish:
> I'd suggest to put the change in ~/.grass.bashrc instead.
Hamish,
don't want to waist your time, but I have put soemthing like
SHORT_VER=`echo "$GRASS_VERSION" | cut -f1,2 -d. | sed -e 's/\.//'`
GLOCATION=`echo "${LOCATION_NAME}"`
GMAPSET=`echo "${MAPSET}"`
export PS1='G$SHORT_VER ${GLOCATION}/${GMAPSET}:\w > '
export PROMPT_DIRTRIM=2
which doesn't work! :-/
Where should $LOCATION_NAME, $MAPSET be fed from?
Thanks, N
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130728/eeff203f/attachment.html>
