[GRASS-dev] [GRASS GIS] #2039: Startup Error
trac at osgeo.org
Sun Jul 28 14:39:31 PDT 2013
Reporter: akdeakin | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: Startup | Version: 6.4.3 RCs
Keywords: wingrass | Platform: MSWindows 7
Cpu: x86-64 |
Comment(by hamish):
it sounds like you have most of the runtime redistributables in place,
msvcr100.dll is a new one though. When you installed did you tick the box
to install "Important Microsoft Redistributable Libraries" on the same
page in the installer as the option to download the sample datasets? Even
though you probably have most already it might be a good idea to try that
anyway.
To see what the error message is you have to stop the window from closing
so fast once it exits. Perhaps the easiest way around that is to open a
command window (start button then type "cmd" into the search and click in
the "C:\>" icon) and from the DOS prompt change into the grass startup
directory then run the startup command by hand.
To make this easy right click on the grass desktop icon and copy and paste
out the "start from" directory to the terminal with "cd
c:\path\goes\here", I think that points to the c:\grass64\msys dir (for
you) but I'm not sure it actually matters.
Then cut and paste the actual startup command into the command terminal,
and wait to see the error.
Is it still "LOCATION_NAME not set"? (which should be recoverable) Do any
of the other grass session menu items work from the grass menu in start
menu -> all programs? For example, if you can start from the text based
command session, maybe that fixes the broken/missing "grassrc6" last-
settings file which remembers the LOCATION_NAME from the previous session.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2039#comment:3>
