[GRASS-dev] [GRASS GIS] #2039: Startup Error
trac at osgeo.org
Mon Jul 29 10:28:07 PDT 2013
Reporter: akdeakin | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: Startup | Version: 6.4.3 RCs
Keywords: wingrass | Platform: MSWindows 7
Cpu: x86-64 |
Comment(by akdeakin):
Hamish,
Thank so much for your detailed suggestions. They are much appreciated!
I did re-download and "install" msvcr100.dll. I uninstalled Grass and re-
installed it, making sure to tick the box next to Important Microsoft
Redistributable Libraries" on the same page in the installer as the option
to download the sample datasets.
While I am able to successfully run the Old TclTk Gui and Command Line
options, I'm still unable to run the new GUI option.
From the DOS command line, when I run grass64svn I get 2 instances of
ImportError: cannot import name MAXREPEAT. Both are preceded by calls to
the Python27 library. (E.g., File "C:\grass64\Python27\lib\site.py", line
548 in <module> main <>)
So, I upgraded from Python 2.7.4 to 2.7.5, but I'm getting the same
response.
Given that I can access Grass through the Old TclTk Gui, this isn't a
priority...I'm just curious, now. ;-)
Thanks, again. I really appreciate your help and your rapid response.
Sincerely,
AKD
Ticket URL: <http://trac.osgeo.org/grass/ticket/2039#comment:4>
