[GRASS-dev] [GRASS GIS] #2039: Startup Error
trac at osgeo.org
Mon Jul 29 11:15:32 PDT 2013
Reporter: akdeakin | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: Startup | Version: 6.4.3 RCs
Keywords: wingrass | Platform: MSWindows 7
Cpu: x86-64 |
Comment(by mlennert):
Replying to [comment:4 akdeakin]:
> Hamish,
> Thank so much for your detailed suggestions. They are much appreciated!
> I did re-download and "install" msvcr100.dll. I uninstalled Grass and
re-installed it, making sure to tick the box next to Important Microsoft
Redistributable Libraries" on the same page in the installer as the option
to download the sample datasets.
> While I am able to successfully run the Old TclTk Gui and Command Line
options, I'm still unable to run the new GUI option.
> From the DOS command line, when I run grass64svn I get 2 instances of
ImportError: cannot import name MAXREPEAT. Both are preceded by calls to
the Python27 library. (E.g., File "C:\grass64\Python27\lib\site.py", line
548 in <module> main <>)
> So, I upgraded from Python 2.7.4 to 2.7.5, but I'm getting the same
response.
This had happened before and was diagnosed at the time as a Python issue
[1], but with version Python < 2.4. Are you sure that the Python used by
your GRASS installation is the system wide one ? It might a Python version
embedded in QGIS ?
To make sure, if that is possible for you, you might want to try to
uninstall all Python installations on your machine + QGIS + GRASS and then
reinstall only GRASS from the standalone GRASS installer.
[1] http://lists.osgeo.org/pipermail/grass-user/2013-May/068106.html
Ticket URL: <https://trac.osgeo.org/grass/ticket/2039#comment:5>
