[GRASS-dev] [GRASS GIS] #2048: i.pansharpen limited to 8-bit imagery
trac at osgeo.org
Mon Jul 29 05:39:04 PDT 2013
Reporter: nikosa | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Imagery | Version: svn-trunk
Keywords: i.pansharpen, sharpening, fusion, brovey, ihs, pca, 8-bit | Platform: Unspecified
Cpu: All |
Getting 11-bit IKONOS bands pan-sharpened by using i.pansharpen works only
if the bands are rescaled to 8-bit, i.e. to range inside [0, 255]. In this
case, color re-balancing (i.e. of Blue, Green and Red fusion-ed with Pan
-IKONOS spectral bands) after the sharpening appears acceptable.
Any other attempts using out of [0, 255] range values, for example using
Top-of-Atmosphere Reflectances (floating point values < 1.0) or the raw
IKONOS bands that range between [0, 2047], are not successful.
Rescaling, however, might lead to some loss of spectral information (?).
Hence, it may not be desired as pan-sharpening should not be limited in
creating nice looking (pseudo-)color composites for viewing tasks (i.e.
image interpretation) or printing. Sharpened/Fusioned images might as well
be used as an input for segmentation/classification etc.
Looking at the i.pansharpen source code ([http://lists.osgeo.org/pipermail
/grass-user/2013-July/068700.html as suggested by Moritz Lennert in the
grass-user mailing list]) ''I see that in all algorithms a function for
histogram matching is called and IIUC, in that function, values seem to be
limited to [0,255]''.
Related code(lines):
[http://trac.osgeo.org/grass/browser/grass/trunk/scripts/i.pansharpen/i.pansharpen.py#L348
def matchhist] and
[http://trac.osgeo.org/grass/browser/grass/trunk/scripts/i.pansharpen/i.pansharpen.py#L379
arrays[i] = np.zeros((256,),dtype=('i4,f4'))]
Not sure if this is a defect or an enhancement request. Many of the High
Resolution images are frequently delivered in >8-bit formats.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2048>
