[GRASS-dev] [GRASS GIS] #2048: i.pansharpen limited to 8-bit imagery
GRASS GIS trac at osgeo.org
Mon Jul 29 10:48:38 PDT 2013
 Reporter:  nikosa                                                     |       Owner:  grass-dev@…
     Type:  defect                                                     |      Status:  new
 Priority:  normal                                                     |   Milestone:  7.0.0
Component:  Imagery                                                    |     Version:  svn-trunk
 Keywords:  i.pansharpen, sharpening, fusion, brovey, ihs, pca, 8-bit  |    Platform:  Unspecified
      Cpu:  All                                                        |
Comment(by cmbarton):
 The question is whether the histogram matching code can handle resolutions
 of >8 bit.
 And I guess I don't know. Have to make some modifications and see.
 That said, the HIS pan sharpening only works with integers, because that
 is a limit of i.rgb.his and i.his.rgb. I don't know if they can handle
 integer ranges outside 0-255, however. You might give it a try to
 transform one of your images with one of these and see what it converts it
 to.
 Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/2048#comment:1>
