[GRASS-dev] [GRASS GIS] #2048: i.pansharpen limited to 8-bit imagery
trac at osgeo.org
Mon Jul 29 14:33:53 PDT 2013
Reporter: nikosa | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Imagery | Version: svn-trunk
Keywords: i.pansharpen, sharpening, fusion, brovey, ihs, pca, 8-bit | Platform: Unspecified
Cpu: All |
Comment(by nikosa):
Replying to [comment:1 cmbarton]:
> The question is whether the histogram matching code can handle
resolutions of >8 bit.
> And I guess I don't know. Have to make some modifications and see.
Can we alter the manual somehow? To show how it can be done (now) with
>8-bit images? I have already posted some example at
[http://grasswiki.osgeo.org/wiki/IKONOS#Pan_Sharpening].
> That said, the HIS pan sharpening only works with integers, because that
is a limit of i.rgb.his and i.his.rgb. I don't know if they can handle
integer ranges outside 0-255, however. You might give it a try to
transform one of your images with one of these and see what it converts it
to.
I can/will try to check. First look in the manual of `i.rgb.his` does not
mention anything about bit-depth(s).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2048#comment:3>
