[GRASS-dev] [GRASS GIS] #2048: i.pansharpen limited to 8-bit imagery
trac at osgeo.org
Mon Jul 29 15:16:12 PDT 2013
Reporter: nikosa | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Imagery | Version: svn-trunk
Keywords: i.pansharpen, sharpening, fusion, brovey, ihs, pca, 8-bit | Platform: Unspecified
Cpu: All |
Comment(by cmbarton):
If you have an image set that is more than 8bit, I can use it to test some
things.
i.histo.match is a nice module. But its objective is different from
histogram matching in i.pan.sharpen. So it would need modification to be
used in this context. When I was writing i.pan.sharpen, I looked at the
i.histo.match code but it was easier to use a much simpler algorithm. But
since you know i.histo.match maybe you can see where the code could be
modified to be used in i.pan.sharpen.
Thanks
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/2048#comment:4>
