[GRASS-dev] [GRASS GIS] #2048: i.pansharpen limited to 8-bit imagery
trac at osgeo.org
Tue Jul 30 09:38:49 PDT 2013
Reporter: nikosa | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Imagery | Version: svn-trunk
Keywords: i.pansharpen, sharpening, fusion, brovey, ihs, pca, 8-bit | Platform: Unspecified
Cpu: All |
Comment(by cmbarton):
For pan sharpening, the reason for histogram matching is that the higher
resolution pan image needs to replace one of the lower resolution images
as part of the sharpening algorithm. So the pan band needs to be histogram
matched to the one it is replacing. This is why I don't think that
matching it to an average of all bands is a good idea. I could be
mistaken, but it seems incorrect conceptually.
The routine I used is the standard one discussed for this. There may well
be a more accurate one and a better way to deal with floating point and
large integer data. Using numpy arrays makes this one quite fast. It might
benefit from parallelization in some way. I parallelized other parts of
the code but not this one. So, yes, if there is a student out there with
not enough to do... ;-)
Michael
Ticket URL: <https://trac.osgeo.org/grass/ticket/2048#comment:9>
