[GRASS-dev] [GRASS GIS] #1961: wxNVIZ: error if no raster map selected
trac at osgeo.org
Sat Jun 1 00:25:25 PDT 2013
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: wxGUI | Version: svn-develbranch6
Keywords: wxnviz | Platform: All
Cpu: x86-64 |
Comment(by hamish):
here's a traceback if I load a raster then a vector-areas map in 2D mode,
switch to 3D mode, then change the order of the two in the layer list in
the Map Layers tab by dragging the vector map to the bottom of the list:
Starting 3D view mode...
Loading raster map <elevation.10m at PERMANENT>...
Translating colors from raster map
Vector map <fields7 at grass7> loaded (261 features)
File "/home/hamish/src/grass/svn/trunk/dist.x86_64
-unknown-linux-gnu/etc/gui/wxpython/lmgr/layertree.py", line
1303, in OnChangeSel
if self.layer_selected.IsChecked():
AttributeError
'NoneType' object has no attribute 'IsChecked'
Raster map <elevation.10m at PERMANENT> unloaded successfully
Vector map <fields7 at grass7> (lines) unloaded successfully
1202, in OnLayerChecked
npoints, nlines, nfeatures, mapIs3D =
self.lmgr.nviz.VectorInfo(mapLayer)
AttributeError
'NvizToolWindow' object has no attribute 'VectorInfo'
1311, in OnChangeSel
self.lmgr.nviz.UpdatePage('vector')
-unknown-linux-gnu/etc/gui/wxpython/nviz/tools.py", line
4520, in UpdatePage
self.UpdateVectorPage(layer, data['vector'])
4710, in UpdateVectorPage
vInfo = grass.vector_info_topo(layer.GetName())
AttributeError
'NoneType' object has no attribute 'GetName'
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1961#comment:10>
