[GRASS-dev] [GRASS GIS] #1961: wxNVIZ: error if no raster map selected
trac at osgeo.org
Sat Jun 1 00:35:06 PDT 2013
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: wxGUI | Version: svn-develbranch6
Keywords: wxnviz | Platform: All
Cpu: x86-64 |
Comment(by hamish):
Replying to [comment:7 annakrat]:
> Replying to [comment:6 hamish]:
> > restarting the GUI in devbr6 and adding Spearfish's roads did not go
well,
> > nothing rendered, lots of this repeating in the terminal:
> > (.:25449): Gtk-CRITICAL **: gtk_range_set_range: assertion `min <
max' failed
> > and endless repeating tracebacks:
> please test r56500
still happens.
grass7, start g.gui, add roads vector map, go to 3d mode:
Starting 3D view mode...
Vector map <roads7 at grass7> loaded (746 features)
File "/home/hamish/src/grass/svn/trunk/dist.x86_64
-unknown-linux-gnu/etc/gui/wxpython/nviz/mapwindow.py", line
376, in OnPaint
self.DoPaint()
398, in DoPaint
self.lmgr.nviz.UpdatePage('cplane')
-unknown-linux-gnu/etc/gui/wxpython/nviz/tools.py", line
4570, in UpdatePage
self.FindWindowById(self.win['cplane']['position']['z']['sli
der']).SetValue(zRange[0])
File "/usr/lib64/python2.6/dist-
packages/wx-2.8-gtk2-unicode/wx/_controls.py", line 2672, in
SetValue
return _controls_.Slider_SetValue(*args, **kwargs)
OverflowError
long int too large to convert to int
376, in OnPaint
self.DoPaint()
398, in DoPaint
SetValue
OverflowError
Switching back to 2D view mode...
Vector map <roads7 at grass7> (lines) unloaded successfully
376, in OnPaint
self.DoPaint()
389, in DoPaint
self.LoadDataLayers()
1327, in LoadDataLayers
self.LoadVector(item, points = False)
1734, in LoadVector
toolWin.UpdatePage('vector')
packages/wx-2.8-gtk2-unicode/wx/_core.py", line 14564, in
__getattr__
raise PyDeadObjectError(self.attrStr % self._name)
wx._core
PyDeadObjectError
The C++ part of the NvizToolWindow object has been deleted,
attribute access no longer allowed.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1961#comment:11>
