[GRASS-dev] t.connect placement
Sören Gebbert
soerengebbert at googlemail.com
Sun Jun 2 08:52:13 PDT 2013
Hi Martin,
the module t.connect is a C module and must be build before the python
temporal library, since the library was making use of this module at import
time. That's the reason why this module is located in lib/temporal. That
wasn't a good solution. So i have implemented an init() method in the
python temporal library that make use of t.connect at run time. I think it
may be safe now to move t.connect into the temporal module directory. I
will check this.
Best regards
Soeren
2013/6/2 Martin Landa <landa.martin at gmail.com>
> Hi,
> just a quick observation. Shouldn't be `t.connect` placed in
> `temporal` directory
> instead of
> `lib/temporal`
> Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130602/dfa716af/attachment.html>
