[GRASS-dev] t.connect placement
Sören Gebbert soerengebbert at googlemail.com
Sun Jun 2 10:05:03 PDT 2013
done in r56562
2013/6/2 Sören Gebbert <soerengebbert at googlemail.com>
> Hi Martin,
> the module t.connect is a C module and must be build before the python
> temporal library, since the library was making use of this module at import
> time. That's the reason why this module is located in lib/temporal. That
> wasn't a good solution. So i have implemented an init() method in the
> python temporal library that make use of t.connect at run time. I think it
> may be safe now to move t.connect into the temporal module directory. I
> will check this.
> Best regards
> Soeren
> 2013/6/2 Martin Landa <landa.martin at gmail.com>
>> Hi,
>> just a quick observation. Shouldn't be `t.connect` placed in
>> `temporal` directory
>> instead of
>> `lib/temporal`
>> Martin
>> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130602/9bcaacbd/attachment.html>
