[GRASS-dev] Unexpected "v.db.select separator=newline" output
Martin Landa landa.martin at gmail.com
Wed Jun 5 02:20:45 PDT 2013
2013/6/5 Nikos Alexandris <nik at nikosalexandris.net>:
> Do I really need to recompile the complete stuff?  Yesterday it didn't work
> with a single "make" inside the "v.db.select" nor inside the complete "vector"
> category?
running `make` from `v.db.select` is enough (assuming that you don't
use `make install`). Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
