[GRASS-dev] Unexpected "v.db.select separator=newline" output
Nikos Alexandris
nik at nikosalexandris.net
Wed Jun 5 02:22:41 PDT 2013
Nikos Alexandris:
> > Do I really need to recompile the complete stuff? Yesterday it didn't
> > work with a single "make" inside the "v.db.select" nor inside the complete
> > "vector" category?
Martin Landa wrote:
> running `make` from `v.db.select` is enough (assuming that you don't
> use `make install`). Martin
Right, I don't "make install". Hmm, I'll give it a quick try...
Thanks, N
