[GRASS-dev] Unexpected "v.db.select separator=newline" output
Nikos Alexandris
nik at nikosalexandris.net
Wed Jun 5 02:26:33 PDT 2013
On Wednesday 05 of June 2013 12:22:41 Nikos Alexandris wrote:
> Nikos Alexandris:
> > > Do I really need to recompile the complete stuff? Yesterday it didn't
> > > work with a single "make" inside the "v.db.select" nor inside the
> > > complete
> > > "vector" category?
> Martin Landa wrote:
> > running `make` from `v.db.select` is enough (assuming that you don't
> > use `make install`). Martin
> Right, I don't "make install". Hmm, I'll give it a quick try...
Nope!
# just did...
/geo/osgeo/src/grass_trunk/vector/v.db.select$ make
gcc -g -O2 -I/geo/osgeo/src/grass_trunk/dist.x86_64-unknown-linux-
gnu/include -I/geo/osgeo/src/grass_trunk/dist.x86_64-unknown-linux-gnu/include
-D_FILE_OFFSET_BITS=64 -I/usr/local/include -I/usr/local/include -
DPACKAGE=\""grassmods"\" -I/usr/include/postgresql -
I/geo/osgeo/src/grass_trunk/dist.x86_64-unknown-linux-gnu/include -
I/geo/osgeo/src/grass_trunk/dist.x86_64-unknown-linux-gnu/include -o
OBJ.x86_64-unknown-linux-gnu/main.o -c main.c
main.c: In function ‘main’:
main.c:180:2: warning: format not a string literal and no format arguments [-
Wformat-security]
: && gcc -L/geo/osgeo/src/grass_trunk/dist.x86_64-unknown-linux-gnu/lib -
L/geo/osgeo/src/grass_trunk/dist.x86_64-unknown-linux-gnu/lib -Wl,--export-
dynamic -Wl,-rpath-link,/geo/osgeo/src/grass_trunk/dist.x86_64-unknown-linux-
gnu/lib -o /geo/osgeo/src/grass_trunk/dist.x86_64-unknown-linux-
gnu/bin/v.db.select OBJ.x86_64-unknown-linux-gnu/main.o -
lgrass_vector.7.0.svn -lgrass_dbmiclient.7.0.svn -lgrass_dbmibase.7.0.svn -
lgrass_gis.7.0.svn -lm
if [ "/geo/osgeo/src/grass_trunk/dist.x86_64-unknown-linux-
gnu/bin/v.db.select" != "" ] ; then
GISRC=/geo/osgeo/src/grass_trunk/dist.x86_64-unknown-linux-
gnu/demolocation/.grassrc70 GISBASE=/geo/osgeo/src/grass_trunk/dist.x86_64-
unknown-linux-gnu PATH="/geo/osgeo/src/grass_trunk/dist.x86_64-unknown-linux-
gnu/bin:/geo/osgeo/src/grass_trunk/dist.x86_64-unknown-linux-gnu/bin:$PATH"
PYTHONPATH="/geo/osgeo/src/grass_trunk/dist.x86_64-unknown-linux-
gnu/etc/python:/geo/osgeo/src/grass_trunk/dist.x86_64-unknown-linux-
gnu/etc/python:$PYTHONPATH"
LD_LIBRARY_PATH="/geo/osgeo/src/grass_trunk/dist.x86_64-unknown-linux-
gnu/lib:/geo/osgeo/src/grass_trunk/dist.x86_64-unknown-linux-
gnu/lib:/usr/local/lib" LC_ALL=C /geo/osgeo/src/grass_trunk/dist.x86_64-
unknown-linux-gnu/bin/v.db.select --html-description < /dev/null | grep -v
'</body>\|</html>' > v.db.select.tmp.html ; fi
VERSION_NUMBER=7.0.svn VERSION_DATE=2013 \
python /geo/osgeo/src/grass_trunk/dist.x86_64-unknown-linux-
gnu/tools/mkhtml.py v.db.select > /geo/osgeo/src/grass_trunk/dist.x86_64-
unknown-linux-gnu/docs/html/v.db.select.html
VERSION_NUMBER=7.0.svn /geo/osgeo/src/grass_trunk/dist.x86_64-unknown-linux-
gnu/tools/g.html2man.py /geo/osgeo/src/grass_trunk/dist.x86_64-unknown-linux-
gnu/docs/html/v.db.select.html /geo/osgeo/src/grass_trunk/dist.x86_64-unknown-
linux-gnu/docs/man/man1/v.db.select.1
rm v.db.select.tmp.html
# revision?
g.version -g
version=7.0.svn
date=2013
revision=56593M
build_date=2013-05-05
Will check tonight. Thanks, N
