[GRASS-dev] OpenMP version of r.series
Sören Gebbert soerengebbert at googlemail.com
Wed Jun 5 07:57:50 PDT 2013
just for your information:
I have created an OpenMP enabled version of r.series to parallelize the
inner processing loop. The speedup is about 10%-15% for really large
datasets (thousands of maps, each map millions of cells).
The code is available here as tar.gz:
http://www-pool.math.tu-berlin.de/~soeren/grass/
However, i will not commit the "improvement" to svn, since the speedup is
so low and only relevant for huge datasets.
Best regards
Soeren
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130605/5c67ccf8/attachment.html>
