[GRASS-dev] GRASS 7 crashes on startup on Mac
Anna Petrášová
kratochanna at gmail.com
Wed Jun 5 12:01:02 PDT 2013
On Wed, Jun 5, 2013 at 1:40 AM, Michael Barton <Michael.Barton at asu.edu>wrote:
> Anna,
> Still crashes.
> See below.
>> On Mon, May 13, 2013 at 11:51 PM, Michael Barton <Michael.Barton at asu.edu>wrote:
>>> Perhaps I discovered the problem. Both the distribution version
>>> (downloaded in the past hour) and (of course) the compiled version of
>>> menudata.xml are empty.
>> Yes, that's what I was thinking. Could you try to run this separately:
>> python core/toolboxes.py > xml/menudata.xml
> I assumed that you want me to run this from the GRASS terminal prompt???
yes. Have you run this from gui/wxpython directory? At least xml directory
must be there.
> bash: xml/menudata.xml: No such file or directory
It's strange that Massimo recently compiled grass7 (with wxpython 2.9, but
it should not be related, no gui is actually involved in this problem) and
he didn't complain about this (Massimo, is that right?).
Anna
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130605/492d9cbf/attachment.html>
