[GRASS-dev] GRASS 7 crashes on startup on Mac
Michael Barton
Michael.Barton at asu.edu
Wed Jun 5 12:59:38 PDT 2013
OK. We are getting somewhere.
If I cd to the ../gui/wxpython directory inside the GRASS-7.0.app and run python core/toolboxes.py > xml/menudata.xml, it appears to create the menudata.xml file
GRASS then launches fine. It continues to launch fine subsequently.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Jun 5, 2013, at 12:01 PM, Anna Petrášová <kratochanna at gmail.com> wrote:
> Hi,
> On Wed, Jun 5, 2013 at 1:40 AM, Michael Barton <Michael.Barton at asu.edu> wrote:
> Anna,
> Still crashes.
> See below.
>> On Mon, May 13, 2013 at 11:51 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
>> Perhaps I discovered the problem. Both the distribution version (downloaded in the past hour) and (of course) the compiled version of menudata.xml are empty.
>> Yes, that's what I was thinking. Could you try to run this separately:
> I assumed that you want me to run this from the GRASS terminal prompt???
> yes. Have you run this from gui/wxpython directory? At least xml directory must be there.
> bash: xml/menudata.xml: No such file or directory
> It's strange that Massimo recently compiled grass7 (with wxpython 2.9, but it should not be related, no gui is actually involved in this problem) and he didn't complain about this (Massimo, is that right?).
> Anna
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130605/9606edcb/attachment.html>
