[GRASS-dev] GRASS 7 crashes on startup on Mac
Anna Petrášová kratochanna at gmail.com
Wed Jun 5 13:35:03 PDT 2013
On Wed, Jun 5, 2013 at 9:59 PM, Michael Barton <Michael.Barton at asu.edu>wrote:
> OK. We are getting somewhere.
> If I cd to the ../gui/wxpython directory inside the GRASS-7.0.app and
> run python core/toolboxes.py > xml/menudata.xml, it appears to create the
> menudata.xml file
> GRASS then launches fine. It continues to launch fine subsequently.
Hm, so the problem is probably in the Makefile. Could you send me the whole
make output (after make distclean)? Unfortunately I have very limited
understanding of makefile rules, I was glad I made it work on my computer.
At least you can use grass7 with this workaround now.
Anna
> Michael
>     ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
> voice:  480-965-6262 (SHESC), 480-727-9746 (CSDC)
> fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> On Jun 5, 2013, at 12:01 PM, Anna Petrášová <kratochanna at gmail.com> wrote:
> Hi,
> On Wed, Jun 5, 2013 at 1:40 AM, Michael Barton <Michael.Barton at asu.edu>wrote:
>>  Anna,
>>  Still crashes.
>>  See below.
>>> On Mon, May 13, 2013 at 11:51 PM, Michael Barton <Michael.Barton at asu.edu
>>> > wrote:
>>>> Perhaps I discovered the problem. Both the distribution version
>>>> (downloaded in the past hour) and (of course) the compiled version of
>>>> menudata.xml are empty.
>>>  Yes, that's what I was thinking. Could you try to run this separately:
>>  I assumed that you want me to run this from the GRASS terminal prompt???
> yes. Have you run this from gui/wxpython directory? At least xml directory
> must be there.
>> bash: xml/menudata.xml: No such file or directory
> It's strange that Massimo recently compiled grass7 (with wxpython 2.9, but
> it should not be related, no gui is actually involved in this problem) and
> he didn't complain about this (Massimo, is that right?).
> Anna
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130605/ea8d534f/attachment-0001.html>
