[GRASS-dev] GRASS 6.4.3 release planning
William Kyngesburye woklist at kyngchaos.com
Wed Jun 5 13:56:00 PDT 2013
Ah, the make install target for OS X is a clone of the main install target, because it needs some custom handling on OS X.  It probably needs to be updated to include the demolocation files.
On Jun 5, 2013, at 3:37 PM, Markus Neteler wrote:
> On Wed, Jun 5, 2013 at 10:08 PM, Michael Barton <michael.barton at asu.edu> wrote:
>> I just was able to test g.extension on GRASS 7 compiled yesterday. I tried it with r.fuzzy because (IIRC) Markus said it is not broken and should install.
>> Unfortunately, it does not yet work. Here is the error. Note that the demolocation is NOT my default or explicitly specified install location ($GRASS_ADDON_BASE is /Users/cmbarton/Library/GRASS/7.0/Modules).
> It seems that demolocation is not found? It is used in the virtual session
> set up during the compilation process which fails below:
>> g.extension extension=r.fuzzy operation=add
>> Fetching <r.fuzzy> from GRASS-Addons SVN (be patient)...
>> Compiling...
>> main.c: In function 'main':
>> ERROR: LOCATION </Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.3.0/demolocation> not available
> Is it possible that the copying of demolocation to that target is not
> happening on Mac? It is actually needed.
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"I ache, therefore I am.  Or in my case - I am, therefore I ache."
- Marvin
