[GRASS-dev] GRASS 6.4.3 release planning
Michael Barton Michael.Barton at asu.edu
Fri Jun 28 09:43:04 PDT 2013
I just tested and all the extensions below install OK (didn't test v.points.cog) in GRASS 6.4 release branch compiled 10 June.
Michael
______________________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 	480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax:          480-965-7671(SHESC), 480-727-0709 (CSDC)
www: 	http://csdc.asu.edu, http://shesc.asu.edu
		http://www.public.asu.edu/~cmbarton
On Jun 11, 2013, at 12:50 PM, Hamish <hamish_b at yahoo.com> wrote:
> Michael wrote:
>> I did a test of g.extension in GRASS
>> 6.4 svn and 6.5. It works fine on the Mac for the test case
>> of r.fuzzy.
>> GRASS 7 still does not work for me, at least with wxPython
>> 2.8 (will be doing more testing on 2.9 later today), but
>> that is not relevant for the 6.4.3 release.
> thanks Michael, I've been looking forward to hearing about
> the state of that.
> for a thorough test, it would be good to check the combination(s)
> of shell script, python script, and compiled C code, both from
> the grass command line (g.extension.sh) and the wxGUI (g.exension.py).
> if it helps save you a few moments of searching, here are some
> nice examples of those from each category
> shell:  r.surf.volcano, v.points.cog, (plug:) d.anaglyph
> python: r.diversity, r.in.wms2
> C code: r.fuzzy, v.in.gshhs
> Other than that, I'm not seeing any reason to wait on the last
> RC for 6.4.3, then write release announcements and make sure all
> the packing scripts still work in the next week or two while
> that is being tested, and then get the final release out by the
> end of the month, hopefully without much in the way of changes.
> thanks,
> Hamish
