[GRASS-dev] [GRASS-SVN] r56622 -	grass/branches/develbranch_6/mswindows
    Helmut Kudrnovsky
    hellik at web.de
    Thu Jun  6 02:08:05 PDT 2013
Hamish:
>> the change was checked in a couple hours before the nightly build
>> rolled around. The plan was to wait for that, try it, then
>> backport. Total turn around time <12 hours.
>> I don't believe in backporting something* to the stable branch
>> that I haven't already tried in situ.
Markus N:
>If it works for you, it does not necessarily work for others.
>We need to widen up the tests and as observed, the devgrass6
>branch isn't widely used.
I concur with Markus, normally I test/work with releasebranch and trunk,
nearly never with develbranch6. and after some screening the mailing lists
the users may do the same. IMHO a wider testing will only happen with
releasebranch...
>And we will have to create a RC4 due to
>heavy changes done *after* RC3.
grass6.4.3 should go out soon.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Re-GRASS-SVN-r56622-grass-branches-develbranch-6-mswindows-tp5058304p5058333.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
