[GRASS-dev] [GRASS GIS] #1633: Unable to display shapefile attribute table due to pipe characters in dbf field
    trac at osgeo.org
    Tue Jun 11 23:11:40 PDT 2013
field
  Reporter:  richardc     |       Owner:  grass-dev@…
      Type:  defect       |      Status:  reopened
  Priority:  critical     |   Milestone:  6.4.3
 Component:  wxGUI        |     Version:  svn-releasebranch64
Resolution:               |    Keywords:  database, separator
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment(by hamish):
 Hi, attaching proposed patch to fix it by changing the field sep to a
 multi-char string which is highly unlikely to occur naturally. As long as
 we stay with an ascii flat file as the intermediary there will be a finite
 possibility that the fs string could be there in someone's data, but at
 least with the patch the chances of that go to near zero.
 tested on devbr6 + linux, but not Windows.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1633#comment:15>
