[GRASS-dev] [GRASS GIS] #2005: v.db.addtable and postgres schema problem
GRASS GIS trac at osgeo.org
Fri Jun 14 03:53:43 PDT 2013
 Reporter:  davidinosauro  |       Owner:  grass-dev@…
     Type:  defect         |      Status:  new
 Priority:  normal         |   Milestone:
Component:  Database       |     Version:  unspecified
 Keywords:                 |    Platform:  Unspecified
      Cpu:  Unspecified    |
Comment(by mmetz):
 Replying to [ticket:2005 davidinosauro]:
 > Hi all!
 > I'm using GRASS GIS 6.4 with a postgres database connection to a non-
 default schema. Most of tools are fine with it, but `v.db.connect` has a
 wired behavior:
 > When I run v.db.addtable on a map obtained with v.dissolve (thus without
 attribute tables set), it gives a big output (attached) among wich some
 "no such table" message from postgres.
 Please try trunk r56701.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2005#comment:1>
