[GRASS-dev] 'make' hangs indefinitely on compiling with latest v7 weekly & trunk
Hamish hamish_b at yahoo.com
Sat Jun 15 00:32:40 PDT 2013
d.barscale is the first of the display modules, did the db/ modules build ok before that? or were the display modules the
first ones to try to be built?
Hamish
Seth wrote:
> If I compile the latest GRASS v7,
> 'make' gets to a point in the compile
> and stops indefinitely. Does this happen for anyone else?
> (I would report it in trac, but I don't have my password
> with me and it
> sounds difficult to reset.)
> Configure:
> ./configure  --with-freetype
> --with-freetype-includes=/usr/local/include/freetype2
> --with-opengl=aqua
> --without-tcltk --with-libs=/usr/local/lib --enable-64bit
> --enable-shared
> --with-cxx --with-python --with-openmp --with-sqlite
> Make:
> VERSION_NUMBER=7.0.svn
> /usr/local/grass/grass7_trunk/dist.x86_64-apple-darwin12.3.0/tools/g.html2man.py
> /usr/local/grass/grass7_trunk/dist.x86_64-apple-darwin12.3.0/docs/html/displaydrivers.html
> /usr/local/grass/grass7_trunk/dist.x86_64-apple-darwin12.3.0/docs/man/man1/displaydrivers.1
> make -C d.barscale || echo
> /usr/local/grass/grass7_trunk/display/d.barscale >>
> /usr/local/grass/grass7_trunk/error.log
> test -d OBJ.x86_64-apple-darwin12.3.0 || mkdir -p
> gcc  -g -O2
> -I/usr/local/grass/grass7_trunk/dist.x86_64-apple-darwin12.3.0/include
> -D_FILE_OFFSET_BITS=64  -DPACKAGE=\""grassmods"\"
> -o
> OBJ.x86_64-apple-darwin12.3.0/draw_scale.o -c draw_scale.c
> gcc  -g -O2
> -o
> OBJ.x86_64-apple-darwin12.3.0/main.o -c main.c
> : && gcc
> -L/usr/local/grass/grass7_trunk/dist.x86_64-apple-darwin12.3.0/lib
> -L/usr/local/lib   -o
> /usr/local/grass/grass7_trunk/dist.x86_64-apple-darwin12.3.0/bin/d.barscale
> -lgrass_display.7.0.svn
> -lgrass_gis.7.0.svn
> if [
> "/usr/local/grass/grass7_trunk/dist.x86_64-apple-darwin12.3.0/bin/d.barscale"
> != "" ] ; then
> GISRC=/usr/local/grass/grass7_trunk/dist.x86_64-apple-darwin12.3.0/demolocation/.grassrc70
> GISBASE=/usr/local/grass/grass7_trunk/dist.x86_64-apple-darwin12.3.0
> PATH="/usr/local/grass/grass7_trunk/dist.x86_64-apple-darwin12.3.0/bin:/usr/local/grass/grass7_trunk/dist.x86_64-apple-darwin12.3.0/bin:$PATH"
> PYTHONPATH="/usr/local/grass/grass7_trunk/dist.x86_64-apple-darwin12.3.0/etc/python:/usr/local/grass/grass7_trunk/dist.x86_64-apple-darwin12.3.0/etc/python:$PYTHONPATH"
> DYLD_LIBRARY_PATH="/usr/local/grass/grass7_trunk/dist.x86_64-apple-darwin12.3.0/bin:/usr/local/grass/grass7_trunk/dist.x86_64-apple-darwin12.3.0/lib:/usr/local/grass/grass7_trunk/dist.x86_64-apple-darwin12.3.0/lib:"
> LC_ALL=C
> --html-description < /dev/null | grep -v
> '</body>\|</html>' >
> d.barscale.tmp.html ; fi
> ^Cmake[3]: *** Deleting file `d.barscale.tmp.html'
> make[3]: *** [d.barscale.tmp.html] Error 130
> make[2]: *** [d.barscale] Interrupt: 2
> make[1]: *** [subdirs] Interrupt: 2
> make: *** [default] Interrupt: 2
> grass7_trunk sprice$
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
