[GRASS-dev] problem with house.c and GCC-4.7
Vaclav Petras
wenzeslaus at gmail.com
Thu Jun 20 02:44:24 PDT 2013
Hi Yann,
On 27 May 2013 09:51, Yann Chemin <ychemin at gmail.com> wrote:
> Hi
> Using Ubuntu 13.04
> gcc -g -O2 -fPIC
> -I/home/yann/grass_dev/grass_yann/dist.i686-pc-linux-gnu/include
> -D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grasslibs"\"
> -I/home/yann/grass_dev/grass_yann/dist.i686-pc-linux-gnu/include -o
> OBJ.i686-pc-linux-gnu/house.o -c house.c
> house.c: In function ‘house’:
> house.c:10:6: internal compiler error: in rewrite_use_nonlinear_expr, at
> tree-ssa-loop-ivopts.c:6215
> Please submit a full bug report,
> with preprocessed source if appropriate.
> See <file:///usr/share/doc/gcc-4.7/README.Bugs> for instructions.
> Preprocessed source stored into /tmp/cchZKfp8.out file, please attach this
> to your bugreport.
> Anybody under similar condition?
Yes. Did you solved the problem? I suppose that the problem is in
GRASS configuration or packages not in GCC...
Using Linux Mint 15.
Vaclav
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
