[GRASS-dev] problem with house.c and GCC-4.7
Vaclav Petras wenzeslaus at gmail.com
Thu Jun 20 03:08:27 PDT 2013
On 20 June 2013 11:44, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Hi Yann,
> On 27 May 2013 09:51, Yann Chemin <ychemin at gmail.com> wrote:
>> Hi
>> Using Ubuntu 13.04
>> gcc  -g -O2  -fPIC
>> -I/home/yann/grass_dev/grass_yann/dist.i686-pc-linux-gnu/include
>> -D_FILE_OFFSET_BITS=64  -DPACKAGE=\""grasslibs"\"
>> -I/home/yann/grass_dev/grass_yann/dist.i686-pc-linux-gnu/include -o
>> OBJ.i686-pc-linux-gnu/house.o -c house.c
>> house.c: In function ‘house’:
>> house.c:10:6: internal compiler error: in rewrite_use_nonlinear_expr, at
>> tree-ssa-loop-ivopts.c:6215
>> Please submit a full bug report,
>> with preprocessed source if appropriate.
>> See <file:///usr/share/doc/gcc-4.7/README.Bugs> for instructions.
>> Preprocessed source stored into /tmp/cchZKfp8.out file, please attach this
>> to your bugreport.
>> Anybody under similar condition?
> Yes. Did you solved the problem? I suppose that the problem is in
> GRASS configuration or packages not in GCC...
> Using Linux Mint 15.
I just realized that grass-devel rep is only for 64bit, the
compilation problem is on 32bit machine. Can be there some relation?
> Vaclav
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
