[GRASS-dev] problem with house.c and GCC-4.7
Yann Chemin
ychemin at gmail.com
Thu Jun 20 04:15:46 PDT 2013
I have not had that problem after upgrading the machine...
On 20 June 2013 15:38, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On 20 June 2013 11:44, Vaclav Petras <wenzeslaus at gmail.com> wrote:
>> Hi Yann,
>> On 27 May 2013 09:51, Yann Chemin <ychemin at gmail.com> wrote:
>>> Hi
>>> Using Ubuntu 13.04
>>> gcc -g -O2 -fPIC
>>> -I/home/yann/grass_dev/grass_yann/dist.i686-pc-linux-gnu/include
>>> -D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grasslibs"\"
>>> -I/home/yann/grass_dev/grass_yann/dist.i686-pc-linux-gnu/include -o
>>> OBJ.i686-pc-linux-gnu/house.o -c house.c
>>> house.c: In function ‘house’:
>>> house.c:10:6: internal compiler error: in rewrite_use_nonlinear_expr, at
>>> tree-ssa-loop-ivopts.c:6215
>>> Please submit a full bug report,
>>> with preprocessed source if appropriate.
>>> See <file:///usr/share/doc/gcc-4.7/README.Bugs> for instructions.
>>> Preprocessed source stored into /tmp/cchZKfp8.out file, please attach this
>>> to your bugreport.
>>> Anybody under similar condition?
>> Yes. Did you solved the problem? I suppose that the problem is in
>> GRASS configuration or packages not in GCC...
>> Using Linux Mint 15.
> I just realized that grass-devel rep is only for 64bit, the
> compilation problem is on 32bit machine. Can be there some relation?
>> Vaclav
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
