[GRASS-dev] [GRASS GIS] #2008: grass.script's find_program() can't find modules
GRASS GIS trac at osgeo.org
Thu Jun 20 11:10:42 PDT 2013
  Reporter:  hamish    |       Owner:  grass-dev@…
      Type:  defect    |      Status:  reopened
  Priority:  critical  |   Milestone:  6.4.4
 Component:  Python    |     Version:  svn-releasebranch64
Resolution:            |    Keywords:  find_program()
  Platform:  All       |         Cpu:  x86-64
Comment(by glynn):
 Replying to [comment:16 zarch]:
 > > The 'which' implementation of function find_program more suits to the
 name.
 > > But in this case we probably want to only test if we can run it (and
 we
 > > don't want to find it).
 > If you want to test if you can run the command or not, why not simply:
 try:
     ret = self._runCommand(RunCommand, prog='g.proj',
 What is self._runCommand? Or what is "self" for that matter?
 find_program() is a function, not a method. And it isn't part of the
 wxGUI, so it can't use any functions from it.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2008#comment:21>
