[GRASS-dev] [GRASS GIS] #2008: grass.script's find_program() can't find modules
GRASS GIS trac at osgeo.org
Fri Jun 21 01:36:27 PDT 2013
  Reporter:  hamish    |       Owner:  grass-dev@…
      Type:  defect    |      Status:  reopened
  Priority:  critical  |   Milestone:  6.4.4
 Component:  Python    |     Version:  svn-releasebranch64
Resolution:            |    Keywords:  find_program()
  Platform:  All       |         Cpu:  x86-64
Comment(by zarch):
 Replying to [comment:21 glynn]:
 > What is self._runCommand? Or what is "self" for that matter?
 > find_program() is a function, not a method. And it isn't part of the
 > wxGUI, so it can't use any functions from it.
 In my example I'm not using any method...
 I only replace the function "find_program" with "try", in the example that
 you can find:
 http://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/core/render.py?rev=56800#L454
 Index: gui/wxpython/core/render.py
 --- gui/wxpython/core/render.py (revision 56810)
 +++ gui/wxpython/core/render.py (working copy)
 @@ -451,12 +451,13 @@
          """!Return region projection and map units information
          projinfo = dict()
 -        if not grass.find_program('g.proj'):
 -            sys.exit(_("GRASS module '%s' not found. Unable to start map
 -                       "display window.") % 'g.proj')
 +        try:
          ret = self._runCommand(RunCommand, prog = 'g.proj',
                                 read = True, flags = 'p')
 +        except OSError:
 +            sys.exit(_("GRASS module '%s' not found. Unable to start map
 +                       "display window.") % 'g.proj')
          if not ret:
              return projinfo
 As you see probably we don't need to define a new function...
Ticket URL: <https://trac.osgeo.org/grass/ticket/2008#comment:22>
