[GRASS-dev] g.proj not found
Luca Delucchi lucadeluge at gmail.com
Fri Jun 21 00:58:48 PDT 2013
Hi devs,
just update grass7 and the gui doesn't start, the problem seems
related to missing module g.proj, but I think probably is related to
find_program.
find_program('r.proj','help') and also find_program('r.proj') return
false instead find_program('ls') return true
the error is
GRASS module 'g.proj' not found. Unable to start map display window.
I have the same error compiling after a distclean in g.gui.vdigit command.
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
