[GRASS-dev] g.proj not found
Markus Metz
markus.metz.giswork at gmail.com
Fri Jun 21 02:43:14 PDT 2013
On Fri, Jun 21, 2013 at 9:58 AM, Luca Delucchi <lucadeluge at gmail.com> wrote:
> Hi devs,
> just update grass7 and the gui doesn't start, the problem seems
> related to missing module g.proj, but I think probably is related to
> find_program.
> find_program('r.proj','help') and also find_program('r.proj') return
> false instead find_program('ls') return true
> the error is
> GRASS module 'g.proj' not found. Unable to start map display window.
Fixed in r56865.
Markus M
